Estimados genios del Arkitool
Antes que nada, agradecerles por tan maravilloso conjunto de utilidades, !!!!! Las uso a diario, y estoy muy contento con ellas !!!!!
Esto que les copio, es lo que aparece al teclear _txtscr
No se asusten, porque hay muchos lsp y utilidades de terceros que tambien estoy cargando...y que nunca me generaron incompatibilidades con el maravilloso programa de uds
Customization file loaded successfully. Customization Group: IMPRESSION
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Customization file loaded successfully. Customization Group: SPURGE
Customization file loaded successfully. Customization Group: AREAX
Customization file loaded successfully. Customization Group: AREAXLIB
Regenerating model.
<<< iDwgTab : Internet check connection >>>iDwgClipBoard™ application for
AutoCAD(LT) 2000~2010,
Copyright(C) BizIcom 1997-2006
Version : 1.0.0.7 (Beta version)
Updates freely available to BizIcom on :
www.icomtools.com
Email wishlist items, and bug reports to : arx119@empal.com
helpers :
Kim,hyun-yong
GOCAD Min
sung-hyun Hong
Cha,ho-chul
QuikPik(tm) 4.1.0.8 Loaded (QUIKPIK to change settings)
Copyright 2010 ManuSoft (
www.manusoft.com
) All Rights Reserved
Command:
Command:
Command:
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
AutoCAD menu utilities loaded._.MENUUNLOAD
Enter the name of a Customization Group to unload:AREAXLIB
Customization file unloaded successfully. Customization Group: AREAXLIB
_.MENULOAD
Enter name of customization file to load: areaxlib.mnu
Common Dialogs 1.1 . By Lintang Darudjati
AreaX © 1.0 . Written by Lintang Darudjati
System.Reflection.TargetInvocationException: Exception has been thrown by the
target of an invocation. ---> System.IO.FileNotFoundException: Could not load
file or assembly 'Tool-ARKIControles, Version=2012.0.0.0, Culture=neutral,
PublicKeyToken=null' or one of its dependencies. El sistema no puede encontrar
el archivo especificado.
File name: 'Tool-ARKIControles, Version=2012.0.0.0, Culture=neutral,
at Tool_LoadApp.Clases..ctor()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure
logging.
To turn this feature off, remove the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog].
--- End of inner exception stack trace ---
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean
publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor,
Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean
fillCache)
at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean
skipVisibilityChecks, Boolean fillCache)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at Autodesk.AutoCAD.Runtime.Factory.Create(Type type)
Boolean bLispFunction)
******* CONJUNTO DE COMANDOS PARA MANEJAR TEXTOS CORRECTAMENTE CARGADOS *******
***COMMAND: CTEXT = Esta función copia el contenido de un texto a otro que se
pedirá en pantalla.
***COMMAND: TXTOAD = Rutina que convierte un texto, que se pedirá en pantalla,
en atributo definición.
***COMMAND: ADTOTXT = Rutina que Convierte TODOS los atributos definición de un
dibujo en textos.
***COMMAND: PROTEXT = Esta rutina permite modificar varios textos a la vez, que
se pedirán en pantalla, cambiando a mayúsculas o minúsculas, subrayado, ángulo,
estilo o altura... para los que no tienen el Express 1-9 claro esta
***COMMAND: CHT = Esta sirve para cambiar las PROPIEDADES
(Height/Justification/Location/Rotation/Style/Text/Undo/Width) de 1 o varios
textos que se pedirán en pantalla
***COMMAND: CHTEXT = Esta rutina permite modificar las propiedades de un
conjunto de textos que tengan en común una determinada propiedad...
esta se pedirá en la línea de comandos... aunque hubiera sido mejor que se pida
en pantalla
***COMMAND: TXTEXP = Esta otra rutina permite exportar textos, que se piden en
pantalla, a un archivo *.txt
***COMMAND: TMM = Y por ultimo esta rutina que permite cambiar tamaños de
textos segun la escala a la que se va ha imprimir, trabajan con 1 unidad de
dibujo = 1 metro, viene con ayuda para entenderlo mejor.
Estas rutinas fueron creadas para hacer el bien, asi que usenlas con sabuiduria
Type TJ to start.
ø¤º°`°º¤ø Text2MText.lsp ~ Copyright © by Lee McDonnell ø¤º°`°º¤ø
~¤~ ...Type "T2M" to Invoke... ~¤~
<< Layer Director Enabled >>
ø¤º°`°º¤ø DynOff.lsp ~ Copyright © by Lee McDonnell ø¤º°`°º¤ø
~¤~ ...Type "DynOff" to Invoke... ~¤~
:: Attribute Modification Suite | Copyright © 2010 by Lee McDonnell ::
:: Type "mvAtt", "roAtt" or "edAtt" to Invoke ::
Use OLM to Offset line to midpoint. Use XLM to Draw a line at the midpoint.
:: TabSort.lsp | Version 2.2 | © Lee Mac 2011
www.lee-mac.com
:: Type "TabSort" to Invoke ::
ø¤º°`°º¤ø DTCurve.lsp ~ Copyright © by Lee McDonnell ø¤º°`°º¤ø
~¤~ ...Type "DTCurve" to Invoke... ~¤~
PENDIENTE.LSP 1.0. (Julio Pablo, enero/2000). Orden PTE cargada.
*Cancel*
Assembly file name:
Command: _RIBBON
Command: COMMANDLINE
Command: Specify opposite corner:
Command:
Command:
Command: COT-2PTOS Unknown command "COT-2PTOS". Press F1 for help.
Command: _TEXTSCR
Saludos agradecidos desde Cordoba, ARgentina
Jope
