ARKITool 12 crasches in BricsCAD 12
  • Feanor01
14 años 2 días antes #3668 por Feanor01
ARKITool 12 crasches in BricsCAD 12 Publicado por Feanor01
Hello,
Yesterday I installed ARKITool 12 with BricsCAD v.12. I updated online after the installation, the program automatically loads ok into BricsCAD and all, but the installation seems very instable. It often crashes BricsCAD when I´m using standard ARKITool commands, for example opening a file or "sel-capturapol" etc.
No error messages or anything - it just hangs up/crashes. What could be the problem?
Regards
/David
14 años 2 días antes #3669 por ARKITool
Respuesta de ARKITool sobre el tema Re: ARKITool 12 crasches in BricsCAD 12
Hello,
The program in Bricscad v12 is tested and working properly.
It may be a problem of RAM of PC. What revision of BricsCAD have (write "_Vernum" in BricsCAD)?
  • Feanor01
14 años 2 días antes - 14 años 2 días antes #3670 por Feanor01
Respuesta de Feanor01 sobre el tema Re: ARKITool 12 crasches in BricsCAD 12
VERNUM = "12.2.17
I have 6,0 Gb RAM installed.
I can upgrade BricsCAD to v. 13 if that could solve anything?
Última Edición: 14 años 2 días antes por Feanor01.
14 años 2 días antes #3671 por ARKITool
Hello,
The problem also occurs in a new drawing?
The problem always happens with the same drawing?
Run a software test of RAM memory.
The best would be to connect to your computer and see what the problem is. If you want, please to send an email to tecnico@arkiplan.es.
If memory is the problem, the problem will be the same with Bricscad v13.
  • Feanor01
14 años 2 días antes #3672 por Feanor01
Thank you for fast help, I appreciate much!
* Yes, problem can also occur in a new drawing
* No, different commands make the program crash, and sometimes they work. But the same command also have crashed the program two times in a row earlier...
If you would take the time to connect to my computer and see for your self I would appreciate it! I´ll send an email from gitech[at]bjorlin.fi
  • Feanor01
14 años 1 día antes #3674 por Feanor01
Thank´s a lot for solving my problem!
Great support!!!
Regards
/David
Tiempo de carga de la página: 0.389 segundos
