arkitool icons shows as question-marks
  • Tomas Babka 1
13 años 8 meses antes #3933 por Tomas Babka 1
arkitool icons shows as question-marks Publicado por Tomas Babka 1
Cheers,
I have installed the Arkitool 2012 freeware recently, I followed all instructions on this link: www.arkiplan.es/en/foros/foro-arkitool/3...stalar-ARKITool-2012
and still my Arkitool icons are not working. Instead of icons are question-marks, and after trying of using them autocad tells me, that this command is unknown.
I use AutoCAD 2008, Windows XP.
I hope you find the solution and help me. Thank you,
Tomas Babka
13 años 8 meses antes #3934 por ARKITool
Respuesta de ARKITool sobre el tema Re: arkitool icons shows as question-marks
Hi,
Please type _TEXTSCR in AutoCAD, you see at the top of the window and tell me what it says.
  • Tomas Babka 1
13 años 8 meses antes #3935 por Tomas Babka 1
Respuesta de Tomas Babka 1 sobre el tema Re: arkitool icons shows as question-marks
Hi,
Customization file loaded successfully. Customization Group: DBCONNECT
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
; error: LOAD failed: "C:\\Program Files\\ARKITool
2012\\Menu\\ARKITool\\Inglés\\ARKITool.mnl"
AutoCAD menu utilities loaded.*Cancel*
Command: COMMANDLINE
Command: properties
Command: _textscr
Thanks a lot.
TB
13 años 8 meses antes #3938 por ARKITool
Hi,
The problem is, it does not load the file C:\Program Files\ARKITool 2012\Menu\ARKITool\Inglés\ARKITool.mnl (as you can see in the image).
1º- Verify that the specified file exists. If not exists, reinstall the software.
2º- Try to load the ARKITool menu manually, typing _MENULOAD in AutoCAD.
  • Tomas Babka 1
13 años 8 meses antes #3941 por Tomas Babka 1
Hi,
I used _menuload to load my arkitool tool manually and found the arkitool.mnl file, but arkitool still does not work properly.
Any other option, please?
Thank you, TB
13 años 8 meses antes #3942 por ARKITool
Hi,
Send an email to tecnico@arkiplan.es and we will connect to your computer to see what the problem is.
Tiempo de carga de la página: 0.275 segundos
