menu in arkitool 2012
14 años 6 meses antes #2960 por person
menu in arkitool 2012 Publicado por person
I don't have arkitool2012 in menu bar in autocad 2013 and icons for topography are missing. I wanted to be in english, but it still in spanish . What can I do?
14 años 6 meses antes #2961 por ARKITool
Respuesta de ARKITool sobre el tema Re: menu in arkitool 2012
Hi,
First, to install "ARKItool 2012" asks the language (English have you chosen?)
If you are in Windows 7, Have you disabled UAC?
Only you are missing topography icons or any other?
14 años 6 meses antes #2973 por person
Respuesta de person sobre el tema Re: menu in arkitool 2012
I asked English and I have XP. I tried many times to install and uninstall the program, but with same result. I don't know if anyone have the problem with icons.
Thank you.
14 años 6 meses antes #2978 por person
At every drawing opening ACAD give the mesage cannot find arkitool.cuix in ingles folder.
14 años 6 meses antes #2979 por ARKITool
Hi,
Try make a directory named "Español" in the directory of "ARKITool 2012".
Tell me if you can make.
14 años 6 meses antes #2993 por person
There is a folder with that name
Tiempo de carga de la página: 0.177 segundos
