menu in arkitool 2012
14 años 6 meses antes - 14 años 6 meses antes #2994 por ARKITool
Respuesta de ARKITool sobre el tema Re: menu in arkitool 2012
Hi,
Go to Start+Run and type CMD.
In the window that opens type:
dir c:\xxx > D:\files.txt /s
(replace xxx for the directory of ARKITool 2012)
Send me the files.txt.
Última Edición: 14 años 6 meses antes por ARKITool.
14 años 6 meses antes #2995 por person
Respuesta de person sobre el tema Re: menu in arkitool 2012
The only txt file in Arkitool2012 folder is this
Archivo adjunto Update.txt no encontrado
14 años 6 meses antes #2996 por ARKITool
Hi,
The file to send is: d:\Files.txt (harddisk d:).
14 años 6 meses antes #2997 por person
There's not such a file
14 años 6 meses antes #2998 por person
Maybe because I uninstall the program few minutes ago
14 años 6 meses antes #2999 por ARKITool
Hi,
Logically if you've uninstalled the program does not have anything.
What I need is to send me the directory structure and files you have after installing ARKITool 2012.
For that you have to do the following:
Code:
Go to Start+Run and type CMD. In the window that opens type: dir c:\xxx > D:\files.txt /s (replace xxx for the directory of ARKITool 2012) Send me the files.txt.
Tiempo de carga de la página: 0.255 segundos
